D Wright
10 points
Posted on - 09/10/2016
I want to connect to my PC remotely and perform various operations such as file transfer and media access protocol. Also want to control the mouse and the keyboard input remotely from the same network. Is it possible for connecting remotely to a PC?
What Are The Steps For Connecting Remotely To A PC?
Yes, you can use the inbuilt utility provided by the Windows operating system named Remote Desktop Connection, but you need to also make sure that PC to be connected should be running on pro version of Windows or higher. By using the IP address, you can specify the location of the PC and then Windows will ask for the username and password of the user to be connected. Once provided with everything you will be able to connect it to remote settings.
