A. Meyers
15 points
Posted on - 09/10/2016
I want to connect my Samsung basic phone to PC and transfer all my contacts and messages to PC so that they stay backed up even if I am losing my phone. How can I provide connecting Samsung phone to PC?
S.SAJMIN
15 points
What Are The Steps For Connecting Samsung Phone To Pc?
To connect Samsung phone to PC you can insert the CD provided in box with the phone and install the recommended software to your PC. While installing it might ask you to connect the phone to PC. You can connect is using the USB cable which is recommended.
It can also be connected using a Bluetooth connection which I would not recommend as it is very slow to connect. Once done with the setup the contents can be transferred to PC easily.
