What are the steps done to do Calc reverse rows?
I am using Star Calc for my spreadsheet files. I am new on this software so I would like to ask guide from you on how do you do reverse rows in Calc. Any helpful advice on Calc reverse rows is very appreciated.
Thank you so much!
Answered By 0 points N/A #140018
Hi Bessierromero,
The first thing you do is to highlight the rows click the button for copy then right click you will see the box when you do the right click. Click the Paste Special as you can see the Content of Paste, it’s up to you what do want to execute then below you will see the transpose under operation, check the box and click ok. And there is also other solution to reverse using formula.
Hope it will help.
