Hello guys!
I just needed help to sync all my local disk (C) files into a hard drive.
What are the sync sys internals needed for this?
My actual plan is to simply back-up all my files into local disk (D), but my storage is not enough for this.
Can you help me?
Thank you!
What are the Sync SYS internals needed for backing up files?
Use windows backup tool which you can find if you press right mouse click on C. drive.
After backing up is finished you will get one file which you can add to WinRAR archive and then using WinRAR split your file into several pieces. Now you can store parts of your backup into several location in order to save space.
I hope I helped.
Regards.
Hi there,
I think I can give you an answer for this the best way you can back up making a image file which the output will show as a one file.
Try downloading alcohol 120 from the official site it’s a converted and image (not photo).
Download it and make and image.
Hope these answers helps you
Best of luck,
Taylor B Campos
Thank You.
