What are the System Requirements for Adobe Photoshop CS5
In Adobe photo shop cs5 installation requirements does is it installable on every window type or it is designed for specific windows system
Hello friend,
Photoshop CS5 is an older version of the Photoshop, which is used rarely. Because of that its minimum system requirements and OS support is low. Photoshop CS5 has been out rated by users.
Photoshop CS5 minimum system requirements are given below :
Intel Pentium 4 or AMD Athlon 64
Windows XP or Mac OSX 10.7
512 MB RAM
5 GB hard disk space
1024 x 768 resolution
open GL 2.0 compatibility
DVD-ROM
Adobe flash player 10
For 64 bit 2 GB RAM
For MAC OS Multi core intel processor is needed.
But according to Windows 7 its compatibility is in doubt. The Adobe is not giving a full support for this old version of photoshop. But you can try it installing it in another drive. If you have above requirements and windows XP it will work for you.
Hope you get the answer, have a nice day.
Hey,
Its not made with any specific window as Zori here suggested above; provided you are not using an antique like windows 95. Nearly all applications and softwares work based upon the RAM storage and the Processor speed. Hard disk space is of course required and rarelyit is concerned with whether you are using xp, vista or windows 7.
Notifications
