Hello experts,
I am using a BlackBerry phone for messaging. However, I am unable to send my messages. This device was given from my company and they said, this is an excellent mobile phone. But something is not right as I'm always failed on sending messages. But this is a new phone so I wonder what the issue is. Can someone help?
What are the technical issues for message sending failure?
Hi!
Here I am to provide you with proper solution for you to solve the problem.
Here are the probability reasons why your phone can't deliver information and solutions:
1. This issue is mostly about wireless provider's service, thus if any problems occurred about wireless information, you need to contact the wireless provider's service.
2. Secondly, maybe your cellular phone itself has a problem. Usually if you have used similar phone for a long time, the problem might occurred. Then, you should send your phone to the service center.
3. Third probability is the network is too busy with users keep sending and receiving information from each other. Thus, to avoid this, you should close some applications that are running to allow more space for the information.
4. Furthermore, you can do one thing to allow your phone receive information. You just need to open your Blackberry menu, then chooses option. Next, you must make sure that under network to send over is always switched circuit.
Finally, if you try just only one of these solutions,your cellular phone should be return back to normal.
