What Are The Best VGA To AV Converter Cables Online?
I need a VGA to AV converter cable, and I need it fast. For how much can I get the hands on them and where do I find them?
Amazon and Flipkart provide you with the wide range of VGA to AV converter cables. The cheapest one is available at Rs 299 which is offered by Cables Kart on Amazon. There are also other companies vying in the competition, and you can get the good ones under Rs. 400. There is also the adapter boxes priced at Rs. 800 apiece which offer a better solution.
If you’re looking for a VGA to AV cable converter, try checking this 15 Pin VGA to S-Video 3 RCA Composite AV Cable from Amazon. It is a brand new VGA to AV cable adapter converter that works on laptops and desktop computers that has VGA cards. Take note: your VGA card should support TV-out function to be able to use this adapter converter.
The connector has D-Sub high density 15 pin male to S-Video mini din 4 pin female and RCA jack. It gives high quality signal transmission. The package weighs 141 grams. Also check 2X VGA to S-Video 3 RCA AV TV Out from eBay. The cable includes D-Sub high density 15 pin to S-Video mini din 4 pin female and RCA jack.
If you’ll be using the cable converter on your laptop or desktop computer, make sure your video card supports TV-out function otherwise you need a signal converter box to pair with this adapter.
