What Are The Causes Of Outlook Error 0x800ccc69
What is Outlook error 0x800ccc69? What are the symptoms, and what are the various causes of outlook 0x800ccc69? What is the solution to this?
Outlook error 0x800ccc69 occurs to many Outlook users. This problem arises when an outlook user tries to send an email. If there is some serious problem with the server or there is corruption in PST files, there are high chances of this error to rise.
Symptoms of this error are: freezing of your PC screen, the performance of outlook becomes slow, your inbox repair tool is unable to repair this error.
Various causes of this error are virus or malware infection, windows registry damaged, corrupted PST file is the vital cause of this error and even due to the inappropriate installation of outlook.
The solution for this is you have to open your command prompt and type scanpst.exe this will repair the entire PST file as a corruption of the PST file is the main reason why the error occurs so once the PST file is fixed, this error will also be repaired.
