What does windows update code 3715 mean? What is the overview of this error, which means what is the description of this error, the average time to solve this issue, etc.? Causes of this error and how can I fix it?
What Are The Causes Of Windows Update Code 3715
This error occurs saying windows cannot search for new updates or an error has occurred finding updates. If you update any applications, some of them are not installed, and an unknown error occurs. Windows version above 7 has a solution to this error. Windows update code 3715 is also known as WindowsUpdate_3715 or even WindowsUpdate_3715e. The average time to resolve this issue is forty-five minutes, and its event Id is 1110.
Causes of windows update code 3715 are: firewall blocking installation or due to the firewall, system files corrupted or conflict in the system.
To fix this error, you need to first disable firewall settings temporarily. For that open the Run box by pressing Windows + R, enter firewall.cpl and turn the firewall on or off.
You need to install any anti-virus software which will scan your pc and detect any malware or virus if any.
