What Are The Methods To Fix 0x40000015 Windows 10 Error
I get a pop up when I turn on my PC. It looks like an application error. Please tell me the steps to fix the 0x40000015 Windows 10 error. Here is a snapshot of the pop-up.
You can try the following methods to fix the 0x40000015 Windows 10 error.
Method 1-
a. Press Windows + R.
b. Type cmd admin and press enter.
c. In the command prompt admin, type sfc /scannow, and press enter.
d. Wait for the process to complete.
e. Restart your computer. Your error will be gone.
Method 2
a. Search control panel in the search box near the start menu and open it.
b. In the control panel’s search box type recovery, and press enter.
c. Click on Create a restore point.
d. Click on System Restore.
e. Follow the on-screen prompts to complete the process.
f. Restart your device.
g. Your error must be gone.
