What Are The Methods To Fix The 0x800ccc0f Outlook Error?
I am facing a problem with Outlook. I set up my e-mail address, but I am unable to send or receive e-mails. The error code is 0x800ccc0f. How to fix the 0x800ccc0f Outlook error?
I think you have not set up POP and SMTP correctly. The following methods will guide you to solve the 0x800ccc0f Outlook error.
Method 1
a. Open Outlook.
b. Click on Tools.
c. Go to E-mail Accounts.
d. Click on View or change existing e-mail accounts.
e. Click on Next.
f. In the next window, click on the Add button.
g. Select the POP3 protocol.
h. Next.
i. Enter the required information.
j. Click on Next.
k. Click Finish.
Method 2
a. Press Windows + R.
b. Type Outlook /safe and press enter.
c. Choose your profile and continue.
d. You will be able to use Outlook.
