What Are The Microsoft 435 Specification Lumia?
Hello everyone, I want to switch to Lumia435. Please provide me the Microsoft 435 specification and make my vision little clear. Thanks in advance for the help.
The phone has the Windows8.1 operating system, and battery capacity is 1560 mAH. It has the dimension of 118.10 x 64.70 x 11.70 and weighs 134.10 grams only.
It comes with a touch screen off 4.0 inch.
Microsoft Lumia435 is a single-SIM support and accepts Micro-SIM.
Its RAM capacity is 1GB, and internal storage is 8GB.
The front camera is 0.3 megapixels, and the rear camera is 2 megapixels.
The resolution of the phone is 400 x 800 pixels.
The battery is removable.
The phone is available in four different colors bright green, bright orange, white and black.
The Microsoft Lumia 435 is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled to the public on January 2015 and released on March 2015 measuring 118.1 x 64.7 x 11.7 millimeters and weighing 134.1 grams. It uses micro-SIM card and has IPS LCD capacitive touchscreen display with 16M colors at 480 x 800 pixels screen resolution.
It supports multi-touch. It runs on Microsoft Windows Phone 8.1 upgradable to Microsoft Windows 10 powered by Qualcomm MSM8210 Snapdragon 200 chipset, 1.2 GHz Dual-Core Cortex-A7 processor, and Adreno 302 GPU. It supports microSD expandable up to 256 GB. It runs on 1 GB RAM with 8 GB internal storage. The primary camera supports 2 megapixels with f/2.7 and 36mm featuring geo-tagging and 1/5″ sensor size.
It can record video in 480p at 30 fps. It has a VGA secondary camera that supports 480p video recording. It has 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with hotspot support, Bluetooth 4.0 with A2DP support, GPS with A-GPS and GLONASS support, FM radio with RDS support, and microUSB 2.0. It has built-in proximity and accelerometer sensors. The pre-installed web browser supports HTML5.
Java is not supported. It runs on removable Li-Ion 1560 mAh battery with standby time up to 504 hours both on 2G and 3G. Talk time is up to 21 hours on 2G and 11 hours 45 minutes on 3G. It is available in black, white, green, and orange colors.
