What Are The Microsoft 535 Specification Lumia?
Hello, everyone, I preferred to change my mobile to the Lumia 535. Kindly provide me some Microsoft 535 specification and help me in deciding the model. Thanks in advance for the help.
The Windows8.1 operating system is installing on the phone, and 1905mAh is the capacity of the battery. Dimensions are 140.20 x 72.40 x 8.80, and 146.00 grams is the weight only.
The touch screen is 5.0 inch.
You need single micro SIM to work with Lumia 535.
Internal storage capacity is 8GB, and RAM is 1 GB.
The rear camera is 5 megapixels, and the selfie camera is 5 megapixels.
The resolution of the phone pixels is 540 pixels by 960 pixels.
The battery is removable when needed.
Green, Orange, white and black are the colors available in the market for this phone.
Connectivity options include Wi-Fi, GPS, and Bluetooth.
There are two models of the Microsoft Lumia 535 phone, a single SIM and a dual SIM. Here are the specifications of the single SIM model. The Microsoft Lumia 535 is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled on November 2014 and released on December 2014 measuring 140.2 x 72.4 x 8.8 millimeters and weighing 146 grams.
It uses micro-SIM card and has IPS LCD capacitive touchscreen display with 16M colors at 540 x 960 pixels screen resolution. It supports multi-touch and protected by Corning Gorilla Glass 3. It runs on Microsoft Windows Phone 8.1 upgradable to Microsoft Windows 10 powered by Qualcomm Snapdragon 200 chipset, 1.2 GHz Quad-Core Cortex-A7 processor, and Adreno 302 GPU. It supports microSD expandable up to 256 GB.
It runs on 1 GB RAM with 8 GB internal storage. The primary camera supports 5 megapixels with f/2.4, 28mm, LED flash, and autofocus featuring 1/4″ sensor size and geo-tagging. It can record video in 480p at 30 fps. The secondary camera supports 5 megapixels.
It has 3.5-millimeter jack featuring Active noise cancellation with dedicated mic; Wi-Fi 802.11 b/g/n with DLNA and hotspot support; Bluetooth 4.0 with A2DP, LE, and aptX support; GPS with A-GPS and GLONASS support; FM radio; and microUSB 2.0. It has built-in accelerometer and proximity sensors. The pre-installed web browser supports HTML5. Java is not supported.
It runs on removable BL-L4A Li-Ion 1905 mAh battery with standby time up to 552 hours and talk time up to 11 hours on 2G and 13 hours on 3G. It is available in white, black, orange, green, gray, and blue colors.
