What Are The Symptoms Of Error 0xc00000022
What is error 0xc00000022? What are the symptoms of this error, and what are the causes? How can I fix error 0xc00000022?
This error has been compiled by Neo Smart Technologies. Error 0xc00000022 can be trigged because of missing any DLL files, corrupted files. There are various causes of why this error has occurred, such as, if the access rights are not set correctly, then there are high chances of error 0xc00000022. Even if the system files are corrupted or damaged, then this can also be a reason why the error occurred. To fix this error, you need to first check for the permission issue. Permission should be for all administrators, users, and system if it is not then changing it and apply these changed settings.
Next, you have to check for DLL accessibility issues and then scan for corrupted files. For that, you need to run your command prompt as an administrator and start typing the SFC/SCANNOW command. Once the scanning is performed, you require to boot your system in safe mood and restart your PC.
