What Are The Top 10 Malicious Software Removal Tool?
Malicious software is a great threat to any PC in the network. There are so many malicious software removal tools available that it seems impossible to choose one. What is the top 10 malicious software removal tool?
Answered By 0 points N/A #344952
You are right. I have done a short study on this topic, and I will list out the top 10 malicious software removal tool as follows –
1. Malwarebytes
Malwarebytes is a good free tool to do your task. But the paid version of this software is preferred. It also provides you with a command-line interface.
2. Avast anti-virus
The paid version of Avast is a good choice for removing malicious software. It provides a VPN too.
3. Kaspersky Anti-Virus
Kaspersky provides some free tools, but the paid version of the software is very efficient for your purpose. It comes at a nominal cost.
4. F-Secure SAFE
This software is a little costlier than other software but worth the price. I will not suggest this for a personal PC.
5. AVG
It provides AI-based real-time scanning at a mediocre price. The interface is easy to use.
6. Bitdefender Antivirus Free Edition
This software is the pick of the free tools for a personal PC where you do not play with patches.
7. Norton Power Eraser
A free tool that gives decent protection against most of the malicious software.
8. Advanced SystemCare
Apart from giving protection over threats, this software optimizes your PC (makes it fast).
9. Avira Free Security Suite
A complete suite with PC optimizer, VPN (500 MB per month), and of course, anti-malware in the free version.
10. SpyBot Search & Destroy
The free version of this tool does a decent job of protecting against malware, spyware, and adware.
