What Are The Various D Link Router Troubleshooting Methods?
My internet connection keeps on getting interrupted and works very poorly sometimes. I am using d link router and would like to know various d link router troubleshooting methods.
There are various d link router troubleshooting methods.
Method 1 –
Check whether you are using Bluetooth and WiFi together. If yes, it creates a problem as both the devices use the same frequency and this creates a clash. You need to turn off your Bluetooth and your WiFi will work smoothly.
Method 2 –
Reset your router.
Step 1 – Switch off your router.
Step 2 – Take a paper clip and insert it in the small hole of the router and hold it for 10 seconds.
Step 3 – Power on your router.
Step 4 – Set the internet password in the same way you did when the router was installed.
