Rizza Ong
Posted on - 10/21/2020
I bought a new laptop, and I am installing Windows 10 on it. It has Windows 7 installed. I am stuck at the error 0x80300002. It is a 1TB SATA hard-disk that is set to AHCI. Please help me as the earliest.
What Are The Ways To Troubleshoot The 0x80300002 Error?
Before trying any sophisticated methods to fix the 0x80300002 error, make sure no extra hardware devices are connected to your device. Attach only the installation media.
If the error is not solved, let us follow these steps –
a. Open Disk Management by right-clicking on the start menu.
b. Right-click on the partition.
c. Select Delete Volume.
d. Insert your installation media, and start the installation process.
e. You will get an option called a “select partition.” You need to select “Drive Options.”
f. Create a new partition.
g. Make two partitions – one where the OS will be installed, second will be the primary partition.
h. Finish the installation.
