Jeremy Jack
30 points
Posted on - 11/23/2012
Hello friends,
What are those acer hotkey drivers for win 7? I would like to know the short cut key or hot key function in finding all the possible drivers installed in my windows 7 operating system. We must have to check all the drivers in our pc to avoid some conflicts in the future.
Thanks and Regards,
Jeremy Jack.
Hi Jeremy,
        Hotkey drivers helps you control, modify, or checkout the special use of your function keys or hot keys (Fn+F3, F4, F6, F7, F8, F9*). You can download your acer driver at this website https://www.acer.com/drivers/selection.html
         You can check all the drivers installed on your computer using any of these methods. First, press win(window button) + R to enter Run windows for you to open programs, folders, document, internet resources, and windows. Then type in dxdiag and press Enter. It will display detailed information about DirectX components and drivers installed in your PC (System information, display, sound, inputs). The second method is press windows key + pause/break to go to the Control Panel Home and chose Device manager to display in a tree view of all devices installed and their corresponding drivers. You can do some actions like scanning and updating drivers. A yellow exclamation point beside the driver to prompt you if there is any problem with the driver. You can fix and update it simply by clicking on it.
