What are those Arabic font designs creator?
Hi guys,
I would like to create my own font style like Arabic and any other font languages.
I want software that can let or allow the user to customize a design to make it as a new instance.
I need some information from you guys.
I need a software for this.
Expecting some help,
Thank you.
Answered By 15 points N/A #184471
Arabic fonts usually fall under the category of Calligraphy or Foreign fonts. Because of its popularity there are several free web font sites that provide Arabic font download without charge.
But you intend to create your own, you can check the tools offered by DAZ STUDIO 4.6. The site offers a lot of font creation tools such as the following:
Font Creator worlds most popular font editor
This software is easy to use interface. It lets you select or modify existing font character set of True Type and Open Type. It includes the ability to convert scanned images which of course will enable you to create fonts with your own handwriting.
Scanahand Add a personal touch to your computer
This tool is useful if you want to create custom fonts. It allows you to produce fonts without too much detail on the technicalities of the tool. It very simple to use: create a template, write your characters using a black marker and scan your drawings. Once your target font is created you can immediately install it and ready for use
Enjoy!
