What are those funny code snippets?
What are those funny code snippets? Share with me some important information about this code snippets, where can we possibly find those stuff over the internet? I need some knowledge about funny code snippets. I hope you can share your best ideas.
Waiting for your support, thank you.
Best Answer by Whudson Audrey
Answered By 10 points N/A #175108
The code snippet is a small region of programming term. Text, Source-code and Machine code are used in it. These are operating units originally defined informally programming modules in larger terms.
The Repeated code "cluttered" function is used to clear the function and meanings. Funny code snippet makes you laugh when they appear. Here are the URLS where you will find funny code snippet.
https://googlesystem.blogspot.in/2006/07/collection-of-funny-source-code.html
Answered By 0 points N/A #175109
The particular value snippet is really a tiny region connected with development term. Textual content, Source-code and also Appliance value are utilized within it.
These are operating devices initially described informally development web theme inside much larger terminology. Hilarious value snippet makes you laugh whenever they look. Listed here are the actual WEB ADDRESSES in which you'll discover hilarious value snippet. It is possible to get hilarious value snippet coming from
http://www.filebuzz.com/findsoftware/Funny_Code_Snippet/1.html
I hope it helps you.
