Hello fellows,
What are those word 2010 to pdf relative links? I would like to discuss some points to consider when it comes to Microsoft word 2010 and pdf, it is always been a great feeling learning new things everyday about technology. Please do guide me about ms word and pdf.
Kristen James.
What are those word 2010 to PDF relative links?
PDF is a portable document format. PDF files are very small and easy to share rather than Microsoft word files.
If you use PDF as your document format then you can keep your file format unchangeable.
Microsoft office 2010 allows you to save directly your files into PDF format without using any additional software.
In Word 2010 you can go to FILE and then Select SHARE option. After that select create PDF/XPS Document option.
You cannot modify those document files after you save it as PDF document and if you want to modify those files then use a third party software or keep a copy of that document in word format.
To view those converted PDF file you should have PDF reader software (Acrobat Reader) and you can download it easily.
You can find more information using below link
https://support.office.com/en-us/article/Save-or-convert-to-PDF-or-XPS-d85416c5-7d77-4fd6-a216-6f4bf7c7c110?CorrelationId=7ba4cfe4-085b-48f8-9072-29f2344a9ad7&ui=en-US&rs=en-US&ad=US&ocmsassetID=HA010354239
Thank You
John Major
