What are voldemort db prerequisites and explain them?
What are voldemort db prerequisites? Please explain them in details, if you answered with the help of links that's better.
Voldemort is a system that is designed as an easy to divide and dispense in portions key-value storage system. The data is reproduced automatically over multiple servers in this system. This system more clearly handled the server failures than any other distributed key-value storage system. This system is still a developing system.
Support Links : http://www.project-voldemort.com/voldemort/, https://en.wikipedia.org/wiki/Voldemort_(distributed_data_store)
Voldermot is a distributed key-value storage system used for certain high-scalability storage problems where functional partitioning is not enough in development.
It has a lot of advantages including
1. Data partitioning
2. Easy to do unit testing
3. Storage is fast
It also has several properties including.
1. Data placement
2. Data replication
3. Data partitioning.
And many more as at now it is still in the development stage
