I have an iPhone 8, and I am using it recently. Sometimes, I get Webkit internal error when I use Safari. I am not getting appropriate solutions for it, even in the Apple community. So if anyone who has been using an iPhone for a long time knows how to get rid of this error, share your opinion.
What Are Webkit Internal Error, Its Causes, And Solutions?
I also faced this difficulty, and this is the way how I solved it.
I recommend you back up your phone before doing anything because sometimes you will never know what will happen. Connect the device to a computer and open iTunes. Then, force it to restart. Since you have iPhone 8, you can do so by pressing and quickly releasing the volume up button and do the same with the volume down button. Then, press and hold the side button until you see the recovery-mode. You have to keep doing this until you get the recovery-mode screen don’t stop even if you get the Apple logo.
You will get a popup asking if you want to update or restore your iPhone. Choose update. It will automatically download the software. If your device takes more time, then your phone will exit recovery mode, and you have to repeat the steps all over again.
