What are the Windows Phone limitation?
Is it true that most phones running Windows have limitations like the HTC Titan 4G? It is said that the reason why this model have a lower resolution and no micro-sd slot to expand its internal storage was due to a limitation by Windows.
Answered By 0 points N/A #136810
Yes this is very much true that it is because of the Windows operating system in the HTC Titan 4G their are certain limitations. Since Windows phone 7 only supports 800 x 480 pixels which is a very limited resolution for a 4.7 inch screen which the HTC titan has, and takes 720p instead of 1080p. And yes, there is also no micro SD slot in the HTC phone because of the windows phone 7's lack of support for removable storage. Hope this clarifies it for you!
Calibengr87
