What Are Windows Update Error 0x80240025
While I was updating my windows I got an error which was windows update error 0x80240025 what is this error? What are the early symptoms of this error, and what are the causes of it?
This type of error arises when you try updating your windows it is a critical error, and you should immediately take suitable action as it may be harmful to your computer as some valuable information may lose. Once this error occurs, you should try fixing it manually or automatically. Error 0x80240025 may have symptoms like automatic system shutdown, freezing of your screen, when you are trying to install or update any application it gives you an error, loss of data and opening the important file without your permission.
Some of the causes of error 0x80240025 are due to inappropriate windows OS installation, system infected with a virus, worms, Trojans, incomplete installation of some programs.
