What Are Windows Update Error 0x80246010?
What does windows update error 0x80246010 mean? Why does it occur and what are how I can resolve windows update error 0x80246010?
Windows error 0x80246010 will not allow installing windows update; most of the people also receive an error related to KB4038782. The main cause of this error is Microsoft server overload. Such problems are also caused when your system is affected by viruses or missing DLL files. There are multiple steps in which you can repair this error, such as restart your windows update service. For that press windows + R and type service.msc. Right-click on windows updates service and press start.
To repair the registry key open advanced start-up options and go to the recovery tab. Click on the restart and restart your computer.
Once after changing all the settings, reboot your computer and start your PC.
Error code “0x80246010” is a Windows Update error which prevents users from installing updates for both system and applications. Many users reported the problem when installing Cumulative Update KB4038782 on Microsoft Windows 10. But according to Ugetfix.com, they have detected quite a number of threads mounting on this problem and pointing to different cumulative updates not just Cumulative Update KB4038782.
If you get this error, first thing to try is to restart the Windows Update service. Click “Start”, “Control Panel”, “Administrative Tools”, then double-click “Services”. In “Services” window, scroll down to the bottom and look for the “Windows Update” service then select it. If the service is not running, click “Start” on the upper left corner to start the service.
If the service is running, click “Stop” then “Start” or just go straight to “Restart”. If this doesn’t work, try repairing the registry keys. Press the Windows key then type without quotes “advanced startup options”. Click “Change Advanced Startup Options” in the results then select “Recovery” on the left pane. On the right, under “Advanced startup” section, click “Restart now”.
This reboots the computer in advanced startup mode. Next, select “Troubleshoot”, “Advanced Options”, and then select “Automatic Repair”. Select your administrative account when the system restarts. When the repair is finished, check if you can install the update successfully. If the problem continues, try renaming the Software Distribution folder. Repeat the same steps to locate the Windows Update service then click “Stop”.
After this, open Windows Explorer then navigate to “C:\Windows”. Scroll down and locate the “SoftwareDistribution” folder then rename it to something like without quotes “SoftwareDistributionOld”. Next, start the Windows Update service then restart the computer. Try installing the update again.
Notifications
