What Are Windows Update Error 80246013
While my apps were auto-installing I got an error which was windows update error 80246013 why did this error occur and how can I solve this error and start my auto installation again?
There are multiple purposes why this error befalls and this is one of the influential reasons that this error occurs while auto-updates of windows as well as any applications. Follow the below steps to solve this error:
You need to restart your windows update, for that, you must download utility kit called windows to update diagnostics utility. Once it is downloaded, operate it and understand the instructions on the screen and keep on clicking next. After it is successfully installed, you should reboot your computer and restart it.
After restarting see if you can update your apps now or not. If not, then you need to start update services. For that press windows + R and then type the command services.msc. Go to background intelligent transfer and check status. Locate windows update and check its status also. If the status is stopped, then restart it.
