What is ASCII code and Hexadecimal code?
I would like to ask about the ASCII code and also the Hexadecimal code.Where are these code mostly used and is there any
alternative to these codes?
ASCII Code and Hexadecimal codes are both used for computers. Computers can only understand binary numbers 0 and 1. For it to understand our input, every letter or symbol has a corresponding code assigned to it. For example, ascii code 1 is read by the computer as 0001, 2 is read by the computer as 0010, and so on.
Decimal | Hexadecimal | Binary |
0 | 0 | 0000 |
1 | 1 | 0001 |
2 | 2 | 0010 |
3 | 3 | 0011 |
4 | 4 | 0100 |
5 | 5 | 0101 |
6 | 6 | 0110 |
7 | 7 | 0111 |
8 | 8 | 1000 |
9 | 9 | 1001 |
10 | A | 1010 |
11 | B | 1011 |
12 | C | 1100 |
13 | D | 1101 |
14 | E | 1110 |
15 | F | 1111 |
 table is from http://www.swarthmore.edu/NatSci/echeeve1/Ref/BinaryMath/NumSys.html
Refer to the link for the ascii code and symbols https://www.ascii.cl/ . The first column shows the ascii number, the next column shows the hexadecimal code (these are used to represent large ascii numbers), The last column is the symbol represented by ascii and hexadecimal code.
Hope this helps. Good luck!
ASCII stands for American Standard Code for Information Interchange. It is a character-encoding method that is originally based on the English alphabet that encodes 128 specified characters like the number 0-9, the letters A-Z and a-z, several fundamental punctuation symbols, several control codes that started with teletype machines, and lastly a blank space into the 7-digit binary integers.
ASCII codes correspond to text in communications equipment, computers, and other devices that utilizes text. Almost all modern character-encoding methods are based on ASCII while they support many additional characters. In the computer, a hexadecimal as well as a decimal can be used to produce a character or a symbol. Here are several examples:
