anonymous
7060 points
Posted on - 10/20/2011
Hi Experts,
I have a question about basic computer. It is basically based in the basic knowledge of computer. My question is What is ASCII stands for ? If you have the answer of this question, please tell me the solution of this question.
Thank you
Hi
The ASCII stands for the “American Standard Code for Information Interchange“.
The main purpose of this is to create inter connect ability between various devices. It was an encoding method. It was a standard 7 bit code.
ASCII comes from the word “Any-Key”. That means all the letters, numbers and the other symbols computer will identify with this ASCII code.
In the standers ASCII code has 128 decimal numbers. And the Extended ASCII code has 128 to 255 numbers that represent additional characters.
This ASCII system sued to transfer data through the electronic media for various purposes. There are lot of ASCII converters available today.
Follow this link for more details.
http://www.jimprice.com/jim-asc.shtml
Thank you.
American Standard Code for Information Interchange (ASCII) – a character-encoding used for computer codes, communications equipment and other devices that uses text format. Most ASCII codes in computer uses combinations and Windows has ASCII charts features.
ASCII codes use 32 codes, 0-31 decimal characters. It has this control devices use for printers that use of ASCII. Most ASCII characters and codes can't be found in standard computer keyboards, so a special functions and commands is use to get print this characters.
The most common ASCII codes use is the letter ñ and Ñ. This Spanish letter is not included in the standard keyboard but it's is use by most country to complete, such as Spain and Philippines.
The developer of this telegraphic codes is plain use for communications but it evolved as time passes by. Nowadays, world wide web used the US-ASCII until it was surpassed by UTF-8 on December of 2007.
lee hung
75 points
ASCII stands for American Standard Code for Information Interchange. It is a method that is used to represent text in computers by the use of digital codes or bits. Since computers cannot understand the human representation of text for instance in English words or any other language, there had to be a way that the text will be represented, and this was by the use digital codes which ASCII offers.
When you enter text into your computer, the text is first converted by the computer into ASCII codes, but the process is so fast that is done within nanoseconds and therefore you can even know that it is happening.
Hope this helps.
Lee Hung.
The ASCII stands for the “American Standard Code for Information Interchange “.
It is a method that is used to represent text in computers by the use of digital codes or bits.Since computers cannot understand the human representation of texts for instance in English words,there had to be a way that the text will be represented, and this way by the use of digital codes which ASCII offers.
It was our assignment to know what Assccll stands for.
I was searching for a thread like this.
Thanks, Stefen222 for answering my question
