If I can set up a new domain details within Active Directory (AD) and then access to a workstation with this account, what authorization should give to the user, by error, or the workstation?
What authorization should I give to the user, by error, or workstation?
I guess you will need to give authorization to the user so as they can gain access to the workstation account through both error and the workstation. Since the Active Directory will be installed on the workstation, you will need to make sure that you have configured the domain settings of that computer such that it is the same as the domain settings of the other computers on the network so that you can be able access the user account from whichever point on the network. Some other configurations on the workstation that will matter include the IP addresses that you are using and the sharing options.
-Chalk Talk
