What is the average temperature of AVR?
Dear Homer,
There are lots of chips of AVR available and obviously every AVR of a different model has different operating temperature. So without knowing the exact model of your AVR; I and infact no one can tell you the answer. It would be really good if you let us know the model of AVR you're using. Thankyou
An automatic voltage reulator or AVR as the name suggest its main function is to regulate the level of voltage in an alternating current AC so that it can protect the parts of a system that might be damaged or broken because of the sudden drops or flow of electricity on the system or machine.
The average temperature of an automatic voltage depends on the location or the place where it is install.
The benefits we get from using automatic voltage regulator is that this device will maintain the current flow and make sure that there is a constant quality and quantity of voltage that will be used for the system.
It also protects the power supply and the device on which it is installed.
The temperature of an automatic voltage regulator should be constant so that it will not overheat or affects the device on which it is being use.
