What is the battery life of new Macbook pro 13”?
I have been having battery issues in my old device, so I hope on accessing a new MacBook 13'' it will have a stable battery life, Any expert opinion can help.
Hi Sherrydlongo,
MacBook with 13" monitor as introduced to the market, the battery could last for 5-7 hours depending on the usage. Usually, the battery last depending of the systems you are using or running. If you will use the WiFi and Bluetooth on it gives you 6.75 watts of battery.
Now, if you will do the surfing and play with the brightness levels it will just consume a power of not greater than 12 watts.
If you will surf using your safari and the brightness level sets at very dim level it will go about 8.5 watts. Now if you want to monitor more your software applications installed I recommended that you install software that is called "Batter Health".
This application gives you information and estimated time results that match Apple's exactly.
Asis
Hello Sherrydlongo,
Thank you for posting your question here. You are asking about the battery life of a MacBook pro 13" and its stability. Well, it has up to 7 hour battery life wireless web and it has 30 days stand by time. So the question now "Is it stable?".
As we all know all things has its depreciation and it depends on how you use it that makes it last. But as what I have read on the reviews of the users of this gadget most of them said that the battery life of it is long-lasting and has an excellent performance.
Most of them has a positive feedback. This simply means that apple is producing high quality gadgets equivalent to its price.
Mary
Hello Sherry,
The new MacBook Pro 13 is integrated with 63.5 watt hour lithium polymer battery. It has a 60W MagSafe power adapter and a MagSafe power port. In OS X with 70% backlight the 63.5Wh battery can serve you up to 7 hour and 59 minutes approximately, but, in Bootcamp with the exactly same condition MacBook Pro 13 can serve up to 5 hour and 1 minute.
With advanced chemistry and adapting technology Mac notebook batteries provide up to 1000 recharges. But will give support about 5 hours depending on the brightness level you are using and the usage of multiple applications.
It’s a matter of regret that some MacBook Pro 13 users are complaining that the battery life is not that satisfactory as per Apple’s announcement.
