What is the best 3d text editor software? We are asked to make some 3d text animation using the best software that is easy to learn and use. I wish you could give me a suggestion that will help me a lot with this project. Also include some information about the tutorials.
I recommended you to try this Aurora 3D Animation Maker 12.05.13. That is what I downloaded before when I need also 3D text editor software so I think it is the best. It is an easy to learn, use and aside from that, it is free to download 3D Title Animation Maker Software.
The best 3D text editor software is Adobe After Effects from far.. It has multiple functions and proposes 3D camera view.. and is very useful without being that complicated. If you are seeking for a light software with moderate features, see Aurora 3D software, it's good.
1....
