Hello experts,
What is the best adobe acrobat alternative? The one that has a compatibility measure with Windows 7 64 bit, Windows 7 starter,Windows vista, Windows XP and any Windows operating system because I am a fan of Windows operating systems that is why I need it for all my computer desktops and laptop.
Thank you.
The most popular tool is, of course, Adobe Acrobat, and no wonder: Adobe Systems created the PDF standard. However, Acrobat is not cheap, prices start at $ 299 for the Standard version. So I am creating charts for you with the best of the best alternatives.
PDF reDirect
PDF Sign & Seal
Sumatra PDF
Drumlin PDF Reader
PDF-XChange
PagePlus X2
But I am using Foxit Reader since last 3 Plus years.
Dana Cua
5 points
Adobe Acrobat seems to be the standard for viewing PDF. It has been widely used by most if the computer users in business and even in writing journals and letters. However, Nitro Pro 7 is a good one, too. It is one of the best choices when one gets tires of Adobe. It works in 32-bit and 64-bit Microsoft office. It also works in Microsoft 2010.
You can download it.
Thank you!
WarHeaD
For people who don’t know any better, Acrobat is their first choice when choosing software for all of their PDF needs. While Acrobat has proven to be a sufficient choice for any kind of PDF needs, there are plenty of drawbacks to this software that people need to know about, and there are plenty of good alternatives.
For the people in general Adobe Acrobat is the only software they use for this particular purpose. But no one seems to bother about the drawbacks it has. There are about 30 odd alternative software for adobe acrobat. Some of the names are given below:
1. CutePDF
2. PDF reDirect
3. PDF Creator
4. Nitro PDF
5. Foxit Reader
6. PagePlus X2
Note that you may have to use two or three of these software to equal the functionality of adobe acrobat. Download, Install & Enjoy.
Read more about 30 Alternatives To Adobe Acrobat Cartridge Save Blog by CreativeCloud from the UK's leading supplier of printer cartridges.
Hi Kathryn Masud,
I think best alternatives for adobe acrobat alternative:
PDFedit:
It is the most excellent free alternative to Adobe Acrobat. It is a set of libraries and tools to amend and control PDF files for free. It is essentially for UNIX like OS, but can be used on Windows via Cygwin.
PDFHammer:
It is another first-class free alternative to Adobe Acrobat. It allows you to alter PDF files online for free. You do not require to download or install everything to use this free online PDF editor.
CutePDF Writer:
It is a free PDF printing software that can generate PDF files from any use that has a print functionality.
Hi Kathryn Masud,
If you are looking for the best alternative for adobe acrobat you can check this link: Markantoniou Blogspot adobe acrobat alternatives.
You can find and select the best alternative for your needs. I can also give you some other links for your reference, which is listed below: Computer World Adobe Acrobat Alternatives.
Hope that it would help you find the best Adobe Acrobat Alternative.
