Good Day TechyV!
I need help from the experts please. Can anyone please tell me the best advance compression software? I need to know the features of the different compression softwares and evaluate based on the given strengths, weaknesses and limitations of each software. If you are an expert user of any compression, please share it with me and tell me why do you think it is the best compression software for you. I always knew that the best teacher is always the experience. Nothing beats the experience in telling the best software based on the overall performance of the softwares.
Thanks in advance for sharing.
What is the Best Advance Compression Software?
Dear Allison,
My best recommendation would be System Navigator which I have been using for a while now. It has the best compression ratio (40.1%) and the best number of extraction formats (38). Remember this are the two main features to consider when looking for a good compression tool.
Some of the other features for the tool include password protection, creation of self-extracting archives, multi-volume archives and also can repair damaged archives.
However, you have to buy it for $34.95 and it does not support WinRAR formats.
Hi Allison Ward,
There are many compression software on the internet but i will tell you about the top 2 together with their features.
1. System Navigator
Price: $34.95
ZIP compression ratio: 40.1%
Ratings: 9.00
Number of extraction formats: 38
2. BitZipper
Price: $24.95
ZIP compression ratio: 39.3%
Ratings: 8.55
Number of extraction formats: 46
