Hi expert,
I am facing problems with clipboard assistant software. What is the best in this regard? I need a free one. Please, tell me in detail as I can get the software easily. Please, don’t forget to include the link from where I can download the software easily.
Thanks in advance
What is the best and free clipboard assistant software?
Hello Aabel,
Hope you are doing well.
I am here to help you with you question and I think I will be able to help you. As you mentioned you are having had time with your clip board management software, I am sharing with you one free clip board management software which will allows you to use multi clip board. The software I am talking about is M8 Free Clip Board. Have a quick look at the below screen.
Here is the download link :
http://download.cnet.com/M8-Free-Clipboard/3000-2384_4-10267618.html
