Hello experts,
What is the best anti virus CPU? I would like you to recommend the best antivirus for my computer system and that is also compatible with my windows 7 starter operating system. I know you can help me regarding this matter experts, I want to consult you first before picking one.
What is the best anti virus cpu?
Hi James A. Watkins,
If you are looking for the best quality my suggestion is Norton 360, its user friendly, fast and reliable, every cent you pay is worth it. If you have lesser budgets, you can try Avira or Kaspersky.
Hi James,
Good question James many of the folks will be in dilemma to choose which antivirus for their pc. As different people will have different opinions if you are going to have a specific antivirus just check the system configuration because some antivirus works on high configuration and other on low depending on your specification.
I would like you to prefer Kaspersky this will help you lot by not allowing any virus in to the system and maintains full security for your pc. For Kaspersky you need to have minimum of 1 GB ram it is must.
Dear James,
I have read our question and I can see that you need to consult experts before you buy your new antivirus program for windows 7. I want to tell you that there are many antivirus programs that are compatible with windows 7 such as AVG, Norton or Kaspersky. But I personally use Kaspersky, because it is the only antivirus program I have been using that helped me with computer threats, also it is very secured specially when it comes to buying things online with a credit card, also Kaspersky comes with a unique windows 7 gadget. There is Kaspersky internet security 2013 and Kaspersky anti-virus 2013.
They are both the same for detecting virus and threats and the automatic updates, but if you use the internet a lot and especially if you browse banking sites and buy things online with a credit card I recommend Kaspersky internet security 2013.
This is my advice to you, the decision is up to you of course.
My friends your solutions are superb and thanks for sharing your knowledge. Geace Jovo, you are right. Kaspersky is a boss antivirus and this is a really unique Windows 7 gadget. Following to your advice now I am using it and I am amazed with its activity. I like it and using this now I am able to protect my PC from heinous viruses.
Hi James A Watkins
According to your question also visit this Techyv post too to get more useful tips on best antivirus for your PC.
Seeking a good and the best Anti-Virus
