moira wood
Posted on - 06/03/2012
Last week I had a virus that forced me to reformat my computer system. Now, I am looking for the best antivirus software that are capable of protecting my whole system. Can you recommend only the best antivirus software considering its features? I need highly recommended ones. Thanks.
What is the Best Antivirus?
The first thing to consider when choosing the best antivirus is the "Features" of it. Most antivirus software are easy to install and schedule scans to avoid slowdowns. But the main feature should be, to protect your computer from malware infiltration from web browsing, messengers, or from removable devices. Antivirus should detect and disable the threats. For this, I would recommend the Bitdefender Antivirus Plus. This program is capable of cleaning your PC that is already rotten with infections. Bitdefender has been very useful for me since it protects my credit card information when I am making some online transactions. And they have a 24/7 technical assistance that we can talk through chat, phone or emails.
Bitdefender Antivirus Plus offers efficient security, easy usability, valuable resource usage and attractive pricing. It is considered as the best antivirus software solution with a improved protection and implementation. The installation is quite easy and it has a step-by-step instructions. There is a pre-installation scan and you don't need to reboot before it finished. It has a Autopilot features to set a security-related verdict without asking you to reply. You do not need to configure anything, there is no alerts or any pop-ups.
Bitdefender Antivirus Plus is very effective on blocking, removing and prevents malware. It offers security without getting any issues on its speed. It utilizes a protected browser automatically to keep your online banking transactions safe. You just need to put it on autopilot feature and let it do the decisions. Bitdefender knows when you attach a USB flash disk and it automatically scan it for possible threats. It can also protect online threats, viruses, spyware or phishing scams. Your emails and instant messaging messages are safe also. It can even encrypt your IM chat conversations. Another thing is, it can protect your Facebook and Twitter accounts.
You can purchase Bitdefender Antivirus Plus for $29.95 only. It is very cheap considering all the features that can help you in securing your computer completely. For more information, you can click on the link below:
Bitdefender Antivirus Plus Reviews
