jen dessin
Posted on - 01/11/2013
Hi guys,
What is the best antivirus scanner for java phone? I need an antivirus scanner for other java application in my android mobile phone device which is Samsung Galaxy y. Please give me the most recommended one. I have to take good care of this mobile phone for it is important in my business travel and other online activities when I am away with my computer laptop and desktop.
Expecting some help, thank you.
What is the best Antivirus Scanner for Android phones?
You don’t need antivirus programs for Java phones. They’re system is old which is why no virus was made for such systems. Moreover, android phones don’t require antivirus programs since they are not susceptible to it.
They were made to be invulnerable for such possible infections. Even though you have java applications in your phone, antivirus is not required.
Hey Jen,
Java phones don’t require anti-viruses software. There is no such thing as a virus for phones. If you’re looking for an application against spyware, to fix all misplaced files and possibly make your phone run a bit faster, check out this website: http://norton.afreecodec.com/norton-java-mobile-free-anti-virous-downlod/
Feel free to write back with your problem and the reason why you are looking for an anti-virus, there could be another solution to it.
Hello Jen,
Like others I also have to say that you do not need an antivirus for Java application. But if you use different phone version then you need an Anti-virus. Since we have to stay outside long time for a day, mobile phone is more important than others. Viruses can make our phone insecure and damage our important file. As a result we have to use Anti-virus to keep our phone safe. We can find many antivirus applications to use, but all of them are not affected in removing viruses. As a result we have to make sure about the best Anti-virus. Here I refer three antivirus applications as they have proven to be effective. You can use these for better result.
The first one is AVG Anti-virus, second one is Lookout Security & Antivirus and the third one is Norton Mobile Security. You can download these Anti-virus from this link:
