What is the best antivirus software available in the market now?
Well right now I think it is the top 1 in tDefenderAntivirus that is top 1 on best antivirus list this year the list. personally, I use avast PRO but I am planning to try Kaspersky. You should yry AVAST
Choose what kind depending on your need or usage. Well I hope you like that I recommend that.
Have you tried Avast? or NOD 32?? I am using both of them right now and it works perfectly and protects my Mobo.. Hope this helps.
There is no best anti-virus so far but you. You should take care off course of your files and computers. Avoid them from virus exposure like inserting USB drive into your computer that comes from Internet Café or from public computers like school laboratories. It is up to you how you protect your computer from viruses.
By the way, according to PC Magazine, Webroot Antivirus scores 4.5, PC Tools AV scores 4.0 which is second on the rank. Panda Cloud AV is in third position with 4.0 score also. Next is Double Anti-Spy Professional with 4.0 score, the same with Ad-Aware. BitDefender, Kaspersky, McAfee, Norton and AVG are both in the same rank with 3.5 score.
