What the best Antivirus software on the Internet for Windows 7?
There are several significant security improvements in the Windows 7 operating system, including tools that improve network security, privacy, parental controls and even integrated protection from malware. But even with the heightened security, a separate antivirus software or internet security suite is a must-have.
Though there are different antivirus program for Windows 7, I think 'Microsoft Security Essentials' is the best for your computer to protect against viruses, spyware and other malicious software . It is a new, free consumer anti-malware solution for your computer. It’s available as a no-cost download for Windows XP SP2 and higher, Windows Vista, and Windows 7.
It installs after a quick download and Genuine Windows validation and then stays automatically up-to-date with the latest protection technology and signature updates. It runs quietly in the background and schedules a scan when your computer is most likely idle. You only see alerts when you need to take action.
