What is the best available crm freeware
I am working with a company that has a thousand online freelancer/employees working for them. It is difficult  to store and handle to details, content or work, purchase orders, invoices, etc with only a spreadsheet. I would like to use a crm freeware to do such task. I need to know what is the best among its list of competitors that has the same application.
Best Answer by Dyer Pearlman
Answered By 0 points N/A #134238
There are a lot of CRM freeware applications on the internet. I suggest you to install any 5 of the following:
>>Pipeliner.
>>EQMS 2012 Lite.
>>Top Sales Basic.
>>Sonar CRM.
>>Business Tracker.
All the above are very effective and simple to use. I suggest you to download any of them from their respective official websites only. There are chances of spywares and malwares likely to infect your computer if you download from other sites.
Thanks and regards,
Skarbos Jay.
Answered By 0 points N/A #134239
Hi Zenith,
Custom Relationship Management is an application that allows one to effectively communicate with customers. It is used by sales and marketing agencies because of its power to automate the whole business process. In order to do this, you need a good and reliable CRM. There are a lot of these software in the market but most of them have a price tag. However you will get a free CRM called the Pipeliner which is the most used. I will give you an overview of this software.
1. It will manage your business processes at no cost.
2. You can keep and manage your contacts.
3. It can keep reminders
4. It is simple to use because of its user friendly interface.
5. It gives accurate forecast of your sales
It has good ratings so it is very effective and you can get it for free here https://www.pipelinersales.com/crm/downloads/
