fern bonnie
30 points
Posted on - 02/02/2013
Dear,
I want to convert some video files from AVI to MPEG. I'm looking for a free and stable AVI to MPEG converter for Windows. At the same time I would like to know that, if I convert those files; will it hamper the quality?
Thanks
What is the best AVI to MPEG converter compatible with Windows?
Hello
You can use this converter: http://www.any-video-converter.com/products/for_video_free/
It is called Any Video Converter, and as the name says it converts any audio/video format to any audio/video format including AVi to MPEG file conversion. Speaking about quality, it depends, you have option to set the level of quality. But in theory you shouldn't loose quality if you care what formats are you using.
Regards.
Hi Fern,
Any Video converter is a useful tool to convert any kind of video to any kind. But the free versions always have some limitations and if you could buy one that would be great. I would also suggest Total Video converter and Xlisoft video Converter. I personally use Xlisoft HD video converter which looks most powerful I have ever used.
