What is the best card making program linux?
What is the best card making program linux? I just switch to linux operating system and was on the process of exploring all the features. I am researching about licensed software for card making or designing card layouts but I cannot find one. Can you share some of your ideas?
Virginia Adams.
Answered By 0 points N/A #173363
Formerly there was a card making and designing software for Linux. It calls as KreetingKard and it is not working on the newer versions of Linux.
You can use word editing software for designing and card making on Linux. My options are OpenOffice.org and LibraOffice.org.
OpenOffice.org provides free templates for card designing and card making. So you can use this template for design your card layouts.
Thank You
John Major.
