Hi guys,
What is the best cbr reader for nokia c3? I have 50 files with .cbr file format and needs to be read for some editing reasons. My friend sends the files via Bluetooth and received by my cs3 nokia mobile phone but unfortunately it cannot read the file. I need your help guys.
Hi Stephen,
I will help you to solve your problem. The Nokia C3 phone a very good phone with a lot of features. But unfortunately, it does not support the .cbr format. It is a format mainly associated with comic files. But you can do one thing. Extract the contents of the .cbr file. You will get a bunch of .jpg files. Then you can transfer the files into your phone and see them.
