What is the best Citrix Plugin full config?
Hi there.
I just installed the Citrix Online Plug-in to access applications and virtual desktops from my Physical Windows XP 64 bit desktop.
What is the best Citrix plugin full config with 128 bit encryption?
Any help would be highly appreciated.
Best Answer by Frazier Rothe
Answered By 0 points N/A #141128
Hi Elsietbrown,
The best Citrix Online Plug-in to use is Plug-in 12.3.
This plug-in is supported on Windows XP desktop version so it will work fine for you.
Use the Citrix Online plug-in to access your hosted applications or virtual desktop.
This cumulative release includes support for launching Windows Internet Explorer 9 and several other fixes.
You can download Citrix plug-in 12.3 by clicking on this link.
I hope that will help you.
Answered By 0 points N/A #141127
Hi Elsietbrown,
You have to know that for configuration purposes you can use the Web interface Management Console or the Config.xml file.
You will find the config.xml file typically located under:
C:inetpubwwwrootCitrixPNAgentconf directory, located in the Web Interface Server
A configuration file that is located on the Web interface Server store all the configured options of Citrix online Plug-in.
Range of Parameters saved in the configuration file are the ones that appear in the user's dialog box.
For a full and detailed explanation of how to configure in details this Plug-in I would suggest to look at the link:
Hope this helps,
Cheers,
Frazier
