What is the best computer case brand with sound-deadening material for a gaming PC?
I'm planning to put the Asus P8Z68-V LX with DDR3, MSI 660 TI OC, Intel i5 2.66 GHZ, 500 w PSU. I have a budget of $150.
Any suggestions?
What is the best computer case brand for gaming PC?
Hi William,
Because you are a PC gamer, you must select a computer case with a great ventilation, because your PC is more prone to overheating. Computer fans must spin faster, because more spins, more air production inside the computer case.
I will recommend you this Computer Case:
Antec Performance One P280 – The Antec P280 is a minimalist, beautifully designed case for low-noise computing. The workmanship, cable routing, and design details add up to a very good value for the money. You can buy it at https://www.computershopper.com/components/reviews/antec-performance-one-p280. Its price is only $174. Just add $24 in your budget.
I hope this helps.
