What is the best database management software for a smart one
I want to create a database of with classes and some coding and with a simple intelligence. How do I choose the best database management system software?
Like everything in life, it’s best to put your wishes on the paper. First, make Cost-benefit analysis. How much money are you willing to spend? How good you are in coding? Does it matter to you to have customer support? There are a lot of solutions on the market. The easiest DB software is Microsoft Access. The best open source software is PostgreSQL. If you’re willing to pay some extra cash – you have Oracle, Informix. Basically, the sky is limit, but you have to put on the paper your budget, willing to sacrifice your time, importance of customer support, and user opinions, then choose the best DB software for yourself.
Hi Jacobs,
Here I am recommending you five tools. You can use one of them. All of them are very helpful and easy to use.
1) Microsoft SQL Server Management Studio
2) SQLyog
3) Sequel Pro
4) phpMyAdmin
5) Navicat for MySQL.
But in my opinion, phpMyAdmin is best of all.Â
