What is the best download for alphabetical navigation style?
Hello experts,
What is the best download for alphabetical navigation style? There are so many downloadable alphabetical navigation style over the internet but it seems like I am always having a problem on the downloading process for some compatibility reasons. My operating system is windows 7 starter I hope you can give me the best solution.
Thank you.
Best Answer by Luker Malcom
Answered By 10 points N/A #166065
Hi Amanda,
Are you looking for the jQuery Alphabetical Navigation list? If it is, you can find useful information from the link below:
http://www.ihwy.com/labs/jquery-listnav-plugin/
Otherwise, you need to be specific on which Alphabetical Navigation Style you were looking for.
Thank you
Answered By 5 points N/A #166066
Hello Amanda,
If you are using Java for coding then Java alphabetical navigation scripts or jquery is compatible for that. It should not have any compatibility issue with windows 7 so long as you are the administrator of your system. Alphabetical navigation using HTML should also cause no problem.
See all the list of downloadable styles from free download manager. You can also download some jquery codes for creating slider gallery from this link.
If you want an iPhone style for your contact lists, go to this site and download the complete source. I wish you the best of luck in finding the best style that suits your taste.
