Hi
I am a undergraduate than learning java programming. I need to learn java entity relationship. My friend said that there are few editors and start with a good editor that helps to learn. So what is the best entity relationship editor java?
Thank you
isoft
What is the best entity relationship editor java for beginner?
You can use Mogwai Java Tool for such work. It features Java 2D and 3D mode visual entity relationship modeling and design for databases like MySQL, Postgres, MSSQL and Oracle. It also offers Apache FOP rendered for dot matrix printers, Sparx Enterprise Architect Reports, swing data binding, etc.
Visual 2D and 3D Entity Relationship Design Tool. Supports Oracle, MySQL, Postgres and MSSQL. Allows schema comparisons, reverse engineering and SQL generations. Supports data browsing in 2D and 3D mode over entity dependencies. Supports conversion of database definitions from one dialect to another. Built-in database management feature.
Open source. Download Mogwai from here: https://sourceforge.net/projects/mogwai/
